Toyota Tundra Double cab subwoofer box calcuations
Derel Bertrand
Sorry I ment thoes all referring to the bottom seat
I know you can mod the back seat part, im curious if you spaced the bottom seat up or just let it rest on the top of the sub box
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Here is an online calculator for determining port size: http://www.carstereo.com/help/Articles.cfm?id=31
That calculator gives a pretty conservative number, you should be able to get away with 75% of the port area it recommends, maybe a little less, but if you reduce it too much you will get port noise and compression.
Two 3" ports is only 14 sq in of port area, that's not going to be anywhere near enough. How many watts are you going to put into this thing?
Builds:
Ok now I gotcha. Ty very much. I need 2 3inch ports 14inchs long per side. When my initial figures were done I didnt understand that its not only based on the box but on per speaker as well
So are you figuring 4 total then? If so, they are going to have to be longer than 14", more like 24" to tune you to 35 Hz. Four 3" ports is still be less port area than I'd recommend.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
