Mazdawgs /proffessa's New Build
This is my new project its a 1989 Ford Escort van as you can see it was built for extreme class but plans have changed it now as normal side doors so its semi extreme now my plan is to build a street bassser which plays music,it as windsreen wipers so its road leagal!!It will using 8 x Orion HCCA15.2 and 8X Orion D5000's the box will be a sixth order bandpass with a twist i wll be starting a build log!! the goal of this is to get high output between 25-30hz,not been built for db drag but more for crowd pleasing!! keep you posted :)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
The uk,s first 170db
This is going to be a custom interior again but with strengh in mind
Posted Image
Posted Image
Posted Image
Posted Image
The batteries will be comming out!!
Would you mind sharing the knowledge of getting 50+ at 30hz and lower?
I have been boggling my mind over this ever since I saw the 4 12" Directed's do 150.3 at 23hz.
Does it have to do with port length?
Quarter Wave?
I love chopped and screwed music and most of that style hits in that range and I want to show people how low a 12" can get.
A lot of the hard work as already been done,this as been locked away for four years its juiced too!!
The idea is to build a sixth order series tunned bandpass, with a centre chamber tunned over mid 70-80hz so it holds on to the note to make it musical and the centre chamber controls cone movement,which helps on the slowwed down jams with the peaks in the mid to low 20hz.
I think you just lost the slow people (that means me :blush: ) lol. Looks like it'll be really nice when you're done. mmmm beefy :D
tejcurrent
XS Power
T3
