Air Velocity on WinISD Pro
mrazandrewm
Got it. My max port velocity is 26 m/sec with 0.9998 Ft^3 tuned to 30.81 Hz on 1500w RMS. Is that good? Also, I have my port now firing to the side (towards the third door in a extended cab truck). Will that increase my tuning frequency a bit? There'll probably be 2-6 inches between the port mouth and third door.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
That should be alright!
And it firing off the wall shouldn't increase your tuning frequency. I would just think it would be no different then facing the subs and port back in the trunk of a car.
Cool. Looks like I got it! Thanks!
Speakers: Stock
You can follow my build here.
Speakers: Stock
I have a choice to make between two different designs. Same net volume after port and sub displacement (1.01 Ft^3), and same tuning frequency (33 Hz). Here's the link.
Speakers: Stock
I took a look at your enclosures. I would probably go with option #1 just because firing to the side seems to work a little better in trucks. Probably not much difference between them though.
Builds:
Cool! Thanks! So loading off the side won't affect the tuning or anything?
Speakers: Stock
Everything affects tuning in some way, no matter what you do. As long as there is at least 3" of space between the end of your box and the door or C-pillar or whatever you should be fine.
Builds:
Thank you Triticum! This will be my first time building a subwoofer enclosure so I'll post progress pics and questions if needed.
Speakers: Stock
  • Who's Online   0 Members, 0 Anonymous, 7005 Guests (See full list)
