6th order with 2 t-line ports?
BigJsMonte330
Is it possible or worth it?
uuuhhhhhhh.
You mean a 6th order with really long ports? yeah. You can do anything. But you dont want both sides of your bandpass tuned super low or it wont have a good range of playable notes. Maybe one side is tuned to i dunno, 25hz. That might take a port as long as 50 inches, so then you need to put that somewhere, so it snakes/zigzags so you dont have this huge 50 inch long tube as your port. As for the other side you usually tune higher, maybe 45 or 50hz to get that upper end. That will probably be a short port, 10-15 inches maybe. It all depends what sub you have and how much room you have to work with. Bandpass takes up a lot of room.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
The problem with this is that a t line works on the principal of constructive interference. Essentially it joins the front wave and rear wave together in phase which increases output
Not saying it isn't possible but it certainly becomes more complicated when you have a phase that isn't zero
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
abcboxports-nggid0233-ngg0dyn-480x360x10
because you seem to like boxes that aren't the norm, build the box i have been planning for almost a year now.
dual chamber bass reflex box.
I'm sure you will like it
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
that's a box with 3 equal length ports. tune tbd box to a tune of say 28hz split into 3rds
a 2/3 section and a 1/3rd section. bu.make all 3 ports the same lengths. This will help control xmax at upper and lower hz. so you can put more power to a sub Then rated.
do some research. it's not a easy box to build. but lots of fun.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
How about you ACTUALLY build this box and hear what it sounds like before suggesting it as a successful design or not? I'm still not sold on this design and I'd want REAL unbiased reviews of what it sounds like from others before giving it a go ahead and suggesting it to others. It's a lot of wave manipulation for a driver that has a simple job.
What's holding you back from having this box built? You've had your sub for quite some time now.
Sloppy kisses as always AJ ;)
you got beef with AJ ? hahaha
I was feeling the same way though, I wouldn't recommend a box to someone if I haven't even built it.
the reason im asking for advise is because ive only built sealed/ported boxes.
ive tried to make a 4th order but I made it way to small lol. it wasn't a success. BUT IM NOT DISCOURAGED.
im still very interested in making bandpass boxes.
  • Who's Online   1 Member, 0 Anonymous, 724 Guests (See full list)
