Scotty Cross Posted December 18, 2014 Report Posted December 18, 2014 Build is in a 2000 f250 Crew cab (2) Pioneer TS-W3003D4 12" champion pro series 600 rms 2k max ( wired @ 1ohm ) (1) Pioneer GM-D8604 ( 4 channel FD ) Mids/Highs (4) Pioneer TS-A6885R ( 6x8 4ways ) 60rms 350 max (1) Hifionics Brutus BXI2610D ( 2600 rms @1ohm ) 4 cubic feet painted box ported @ 37htz i have one 0 gauge run from my driver side battery aprox 1 foot to 1st 250amp fuse then 13 feet to back of cab at a manl block houseing a 80amp fuse for my mids amp and a 200a for my mono block. i have a small piece aprox 18" of 4ga coming from the block to the amp. My question is what kinda options do i have to get more power to my amp or is what i have sufficent. i been trying to find a dual anl fuse block with 0ga input with a 0 or 4ga output but i cant seem to find crap so im thinking ive done something wrong. 2001 Chevy Astro Van - DBDRIVE (12) 15" WDX 7k Subs DBDRIVE (6) a7 7500.1h Amps JY Power ( 6 ) 80 ah 16v packs Custom Electric Services (3) 370a 16v Alternators IASCA HEAVYWEIGHT IASCA IDBL USACI STREETBEAT4 #teamTnE #FLORIDABASSHEAD #772 #DBDRIVE #hurtsfeelings #teamDBDRIVE #TEAMJYPOWER #TEAMCustomElectric
rockFord_Expedition Posted December 18, 2014 Report Posted December 18, 2014 Is something not working properly? 4ga to your mids/highs amp is sufficient. If you want more output and more power, first step is to upgrade your alt if you haven't already and another run of 1/0 to the rear. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Scotty Cross Posted December 18, 2014 Author Report Posted December 18, 2014 i have 8ga runing to my mids and 4ga runing to the mono block i just dont wanna under power anything this is my 1st build. i only run the mono block at 60% gain with a 200a fuse but the amp calls for a 250a. im probaly just over thinking. just trying 2 make sure everythings done before i throw the seat back in 2001 Chevy Astro Van - DBDRIVE (12) 15" WDX 7k Subs DBDRIVE (6) a7 7500.1h Amps JY Power ( 6 ) 80 ah 16v packs Custom Electric Services (3) 370a 16v Alternators IASCA HEAVYWEIGHT IASCA IDBL USACI STREETBEAT4 #teamTnE #FLORIDABASSHEAD #772 #DBDRIVE #hurtsfeelings #teamDBDRIVE #TEAMJYPOWER #TEAMCustomElectric
CleanSierra Posted December 18, 2014 Report Posted December 18, 2014 I see what looks like a piece of 1/0 ground going to what I'm guessing is the Hifonics? You should really have the same size power and ground wire going into the amp. An 18" run of 4 gauge is really fine on a stock charging system got that short of a run. You're ground should match though, not be a larger run. There are plenty of single 1/0 and dual out fused distribution blocks. Im not the one you want to try to troll. Just a fyi for you.
rockFord_Expedition Posted December 18, 2014 Report Posted December 18, 2014 Is your wire 100% OFC? The 4 ga wire isn't rated for 200A so that fuse is too big. Probably the same case for the 8ga. Wiring could be a bottleneck in your system but only if your alt makes enough current for this to be the case. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
CleanSierra Posted December 18, 2014 Report Posted December 18, 2014 Is your wire 100% OFC? The 4 ga wire isn't rated for 200A so that fuse is too big. Probably the same case for the 8ga. Wiring could be a bottleneck in your system but only if your alt makes enough current for this to be the case. We are only talking about an 18" run though. It will carry a Hell of a lot of current if it's OFC. On a stock charging system, and such a short run, 4 gauge is fine, Heck I bet CCA would do the trick too. Im not the one you want to try to troll. Just a fyi for you.
Scotty Cross Posted December 18, 2014 Author Report Posted December 18, 2014 I got dual gel battries and dual 240a alternators on my diesel . If you could point me to a DUAL anl block in pm or here id be in your debt i cant seem to find any dual anls itha 0 in 0 out on amazoo or google 2001 Chevy Astro Van - DBDRIVE (12) 15" WDX 7k Subs DBDRIVE (6) a7 7500.1h Amps JY Power ( 6 ) 80 ah 16v packs Custom Electric Services (3) 370a 16v Alternators IASCA HEAVYWEIGHT IASCA IDBL USACI STREETBEAT4 #teamTnE #FLORIDABASSHEAD #772 #DBDRIVE #hurtsfeelings #teamDBDRIVE #TEAMJYPOWER #TEAMCustomElectric
Aj11 Posted December 18, 2014 Report Posted December 18, 2014 hold on a second here, guys Read his pust again! your running 60% gain? your clipping the hell out of your Subs! if you're lights are dimming and you feel like your losing power... you are! turn your gain down, and set it right! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Scotty Cross Posted December 19, 2014 Author Report Posted December 19, 2014 at 2 o clock i have no clipping or dimming at 3 i have the dimming but no change in sound till around 5 2001 Chevy Astro Van - DBDRIVE (12) 15" WDX 7k Subs DBDRIVE (6) a7 7500.1h Amps JY Power ( 6 ) 80 ah 16v packs Custom Electric Services (3) 370a 16v Alternators IASCA HEAVYWEIGHT IASCA IDBL USACI STREETBEAT4 #teamTnE #FLORIDABASSHEAD #772 #DBDRIVE #hurtsfeelings #teamDBDRIVE #TEAMJYPOWER #TEAMCustomElectric
rockFord_Expedition Posted December 19, 2014 Report Posted December 19, 2014 hold on a second here, guys Read his pust again! your running 60% gain? your clipping the hell out of your Subs! if you're lights are dimming and you feel like your losing power... you are! turn your gain down, and set it right! It doesn't mean he's clipping just because his gain is at 60% Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
