Koty Posted December 21, 2014 Author Report Posted December 21, 2014 Thanks now I can start build the box.
Koty Posted December 21, 2014 Author Report Posted December 21, 2014 So here is a suggestion, wood thickness is 19 mm, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 5 centimeters, figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Joe X Is it right that is L port extension is long 44 cm?
Joe X Posted December 22, 2014 Report Posted December 22, 2014 The figure above is just an assembly guide, here's a sketch done to your box dimensions: 44 cm is correct.
