My first box design. what do you think?
gmoxley1
so this is my first box design and use of google sketch up
its for 2 sa 8 v2's at 1.3 cubes tuned to ~38hz for a friend of mine to use in his trunk
what do you think and should i add a brace between the subs?
ScreenShot2014-12-21at125114PM_zps1be9c5
ScreenShot2014-12-21at125238PM_zpsf62df3
ScreenShot2014-12-21at125255PM_zps7c3f93
ScreenShot2014-12-21at125410PM_zps3f35c5
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
Need dimensions, port area, and port length. Overall looks good.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
Sorry last picture with info didn't post
External
34w
10h
14d
Sub displacement is .16
Chamber is 1.46 cubes before subs
Port area is 25.5 in^2
3 inches wide
8.5 inches tall
28.5 inches long
stock alt 105a
Personally, I wouldn't do a labyrinth slot port. Too many 180 degree bends. I would use a simple L-slot port. Also, you should add 45's in the corners to stop standing waves inside the enclosure.
What are the max dimensions available? Does your friend want it tuned that high? Type of music?
Speakers: Stock
Kinda like mrazandrewm said, I would suggest an L-shaped port instead of the labyrinth. I would put 45s in the corners of the ports for better airflow.
I would also suggest a window brace connecting the front baffle with the top, bottom, and back of the box.
Other than that it looks great! Nice job with SketchUp.
Builds:
I absolutely agree on everything and 45s will be added I just didn't know how in sketchup. I would also do a standard L slot but the friend I designed this for likes the the look of a labyrinth port. ( not sure why)
We could make the box bigger but he's going to be running a scv1500 to it he didn't want it too big. The box he has now for his HDC3 15 is tuned to 34 hz and he said he wants it a little higher. So I'm just going by what he says. Haha
stock alt 105a
Double post. Sorry.
Speakers: Stock
I have a sketchup file of 1.2 cubic feet tuned to ~37 Hz using the outer dimensions you gave me with the same port area. I just increased the port length from 28.5" to 37". I also included a window brace and 45s in the corners.
Not related to OP...but Triticum...can you check out which enclosure design I should do for my truck in my thread? Thanks.
Speakers: Stock
Here's the sketchup file...just follow the instructions on the website. LINK
Speakers: Stock
  • Who's Online   1 Member, 0 Anonymous, 5384 Guests (See full list)
