Top post terminal for a 2nd battery
Good Evening,
I' am putting in a 2nd battery but have a question. I only need a top post terminal with 1 o gauge input and 1 o gauge output. My question is can I use something like the stinger SHT303 and use the out as an in and the other out as an out to the amp? If not can someone recommend something beside the big 6 hole custom blocks people are using?
Vehicle: 2001 Oldsmobile Alero Sedan Gold Edition
Headunit: Pioneer AVH-X5500BHS
Front: Polk DB461
Rear: Infinity Kappa 693.11i
Speaker amp: Kenwood Excelon 4/100-4
Sub Stage: Dual 12" Tantric MD's in a 3.2 sealed Cherrycustoms box
Sub Amp: Sound Qubed Q1-2200D
Amp Wiring: Sky High 0 gauge OFC, Sky High 4 gauge OFC and Knuconceptz Krystal RCA Kables
Big 3 Wiring: Sky High 0 gauge OFC
Second battery-Sprinter S12V285F 83ah and H/O Singer 320 alt
It's just a chunk of metal it doesn't know what's out and in, use it however you need to just remember to fuse your wires.
Super thanks bud appreciate it. So as Long as I fuse the power coming from the front near the 2nd battery and run the 0 out to a distro I' am good yes?
Front: Polk DB461
Yep you should be fine.
Fuse for the current demands though not the wires rating.
Are you referring to the 2nd battery fuse?
Front: Polk DB461
Send me a pm! I have some terminals that will work for you.
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
Thanks bud already got everything I need except for the speaker wire for the new box. I' am running two dual 4's in a sealed any idea on how much wire I might need and 12 gauge is ok right?
Front: Polk DB461
  • Who's Online   1 Member, 0 Anonymous, 725 Guests (See full list)
