This is starting to drive me crazy
-Everything highpassed at 63hz Via H/U Hpf---Amp set at Full Range
that clarion eq will be much better than the headunits eq
I was considering it because it would up my rca voltage to 7 volts instead of 2. Pretty much I'm trying to squeeze the best sound I possibly can without having to go for an active setup. Being it ups the voltage to 7 would it give it a cleaner signal comapred to the 2 volts or would the end result be the same. My amp can handle up to 9volt pre outs via high/low switch
