selaed box performace from a ported (prefab) box
Hey guys, i got a dvd head unit installed and i noticed it doesnt have the same bass as before .....like i have to turn it up more for it to start bassin vs before with stock unit just a little. but it does sound ALOT clearer when i turn it up. any suggestions? I have a fairly decent amp (kicker dx 1000.1) so it couldnt be that
Did you readjust the gain?
You could have lower input voltage going to the amp with the new headunit.
Did u have the bass boost up before?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
well most stock headunits Max at volume 12. there's very Lil play between Max and off.
compared to a aftermarket deck like mine that maxes out at volume 50.
also i don't know who installed it the first time but your gain could have been way to high and the last guy actually knew what he was doing. that could be a reason.
but the question that hasn't been asked... you say it takes more clicks of the volume knob to start bassing. Is it still the same output? and just takes longer to get there? or is there a loss of output?
also you say in the title you changed boxes, but in post you don't speak of it... a new box can change everything!
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
The shop u just took it to probably knows what they r doing and turned ur bass boost off
Subs/Amps: TBD
sounds like you have more control over your volume now, and your gain.might be set right.
also never run bass boost! ever! it will just clip your subs and kill your subs.
i truly don't understand why they even make "bass boost" i mean isn't that what the amp does to begin with?
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
