B-Large Posted December 29, 2014 Author Report Posted December 29, 2014 why not just aero port? I will look into it. I'm assuming i would still need a bend. Also not sure what size port i would need. Sub is a fi ssd 12" going into 2.5 cubes and shooting for recommended 33hz.
audiofanaticz Posted December 29, 2014 Report Posted December 29, 2014 I didnt notice the inside of the angled port. which isnt needed if you measure down the middle of the port for the length. otherwise you could do the matched angles on both ends too for the length. So just to be clear leave it as is with matching angles at port entrance and exit, or straight on port entrance measuring length only at center height of port. either could be done, if it was my box it would be straight on the entrance, and measure down the center of the board for the actual length.
B-Large Posted December 29, 2014 Author Report Posted December 29, 2014 I didnt notice the inside of the angled port. which isnt needed if you measure down the middle of the port for the length. otherwise you could do the matched angles on both ends too for the length. So just to be clear leave it as is with matching angles at port entrance and exit, or straight on port entrance measuring length only at center height of port. either could be done, if it was my box it would be straight on the entrance, and measure down the center of the board for the actual length. Thanks for the help.
