power wire question for my mids amp
ok i do i need a distrubution block off the run of 0 gauge from the front that goes to my rear batterys for the mids amp or should i run it directly to rear batterys like the sub amp
Straight off the rear batterys then fuse then amp
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
what if his sub amp draws 300 amps? wouldn't he need to make another wire run? he obviously is running a descent size sub amp to have multiple batteries.
when i last had it setup i had a seperate run of 4 gauge with a 100 amp fuse inline going from front battery to mids amplifer
and subs amp was ran off rear batts that had their own run of 0 gauge to front batt with a 300 amp fuse
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
