how to find the amount of air a subwoofer can displace?
alaskanzx5
Yeah I know I can use winisd. Just like to know the math behind it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Electrical circuit analysis is used to model speaker behavior in an enclosure, the following pic should help:
To keep it simple losses are not represented nor the sub itself, only a ported box, the math unhappily is hard once you factor everything in, not worth it at all since results are always of limited accuracy even in a nearly ideal environment and more so in a car.
  • Who's Online   0 Members, 0 Anonymous, 1879 Guests (See full list)
