99 Explorer 4th order SSA Evils *New alphard amp in!
Nice, Flat response! I hope I get to hear this at LST!
Thanks! It has a slight peak at 27hz (wall) and 41hz (cabin). I don't know if I can make LST, isnt that soon?
Feb 20-22
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
I doubt I could make that. It is 1000 miles from here and that is a month away. I might be at scrapin the coast this year if you are going to that. What is the biggest tx show of the year?
I really like this build. Even more the flat response you have. I bet those SHDs will change the response a bit, nice job on the box too
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
Heatwave or Turkey Drag
Turkey Drag is more basshead friendly I think. And cheaper.
The L@zy Hoe
2005 Chevy Tahoe
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
24K Watts
4 Custom 18s
The Build Log
More testing was done.
Still not sealed off, and it was worse than I thought. Down the sides isn't bad but at the bottom between the boxes around the wheel wheels are still open while we are running cables. Had shoved blankets in there to help seal it off and thought it was doing an ok job but the back window is violent when doing demos so I guess there is a fair amount of pressure being lost.
The roof is beyond done now. We used square stock steel to make a frame. Notched it around the body and welded it in. The sheet metal is super thin at the top so just used epoxy there. Drilled a couple small holes in each tube and filled with foam to make even more rigid and try to prevent any resonance in the tubing.
I like me some steel roof
The L@zy Hoe
2005 Chevy Tahoe
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
24K Watts
4 Custom 18s
The Build Log
Here is a little more detailed otf a pic. You can see how it is notched, welded and then epoxy. Also has a little shot of foam above it. Used a 5/8 roundover to clear the welds and bolted the first piece on. Then shot foam between the wood, frame and roof.
I wasn't going to post any scores yet since there is quite a bit of things left to do. But, I like to test as I go to make sure everything is going in the right direction and to see how changes effect things good, bad or indifferent.
I'll share just so you know a base line. Hopefully it's all up from here.
Not sealed off
Broke roof
Quick external port
2 sp4's in there now with 3rd hole blocked off
~3k power
151.7 at the headrest 27hz
Not sealed off
Broke roof
Quick external port
~3k power
Temp setup for the win! No worries dude my shit is temp and I tell people every time I demo, they think it's loud now so hopefully it gets louder after rebuild!
The L@zy Hoe
2005 Chevy Tahoe
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
24K Watts
4 Custom 18s
The Build Log
  • Who's Online   1 Member, 0 Anonymous, 836 Guests (See full list)
