Charging system failing
I got a hifonics 2600.1, and its draining the crap out of my electrical system. my stock alt. is 170amps. should i upgrade the alt or the battery or just add another battery in the back ?
Maybe both. You could try just a battery, but if you are pushing that amp at 1ohm then you prolly need a better alt.
What do you mean draining the crap out of your system ?...Have you done the big 3?
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
Still prolly need at least a battery. Anything over 1000w prolly needs an upgraded electrical system.
i would check the resting voltage of your current battery and check charging voltage of alt..and do big 3. Then go from there
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
  • Who's Online   0 Members, 0 Anonymous, 4164 Guests (See full list)
