What do i need to run my system?
Ill be running a total 2300 watt rms system. So my question is what electrical do i need? My car already has a 150 amp stock alternator, I know ill need to up grade my stock battery because it sucks. So my options is either add another battery or bigger alternator which would be best or what would you recommend ?
If this is a daily driver which will be played mostly when you're rollin around town, do the HO alt. If this is a show vehicle that needs to play while the vehicle is not running, then batt. Both would be awesome of course, but if you could afford both, you wouldn't be asking this question. lol
2300w should be fine on your alt while driving. I'm running 4k on a 120amp alt with 2 decent bats.
don't mix dry and wet cell batteries.
get a good agm battery for under the hood. If that's not enough... get another bat.
run 0g and do your big 3
don't run below 1ohm
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
please post in the right section.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
