rockFord_Expedition's Rebuild (Old School RF, SMD/D'Amore, CE Auto Electric, DC Power, XS Power, SHCA) lots of pics inside
Looks Great! Like the color!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
clean build nice old school amps
2000 blazer LS
240 mechman
2 b2 HN v3 15s
crescendo bc5500 @.5
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/
142.8db MECA
2016 PA state champ mod 1 class
I left out some of the work I did so I figured it's better to stick it in late than not at all..... that's what she said!!
Anyways, the work is boring but important, and something that alot of people skip. I never used to do this until I learned how important it was.
One of these pics is a repost from the middle of page 3. I must have gotten too excited about getting some bass going that I forgot to post the rest.
Without further ado, here is how I swapped out the factory front door speakers for the RF T2 6.5 components.
Biggest challenge is that the opening is 5x7 so not only am i putting a round speaker in an oval hole, it's also too big.
Step 1, trace the shape and size of the OEM speaker with the flush trim bit
Next I cut the mounting hole. Theres literally less than 1/16" on the short sides. I reinforced the outside with some "bondo glass" which probably wasn't necessary since it will sit inside of the opening and won't be vulnerable to outside pressure.
Not sure if you can tell, but I actually managed to get a slight round over all the way around the mounting hole. I did this because I am using a mounting baffle to seal the air in behind the speaker. This was the only way to close in any air space since the way the power window mechanism is set up, I couldn't seal up the door without restricting the movement of the window. I am also feeding these components about 25% over rated power, so a smaller enclosure is probably best anyway.
Speaker wires pulled through, of course I have to have the female spade connectors for a neat and secure termination
Baffle in, speaker wires pulled through, wire pass through hole about to be sealed up with a little piece of second skin
Speakers mounted and sealed up.
Had some foam laying around and secured it around the speaker in order to direct all the sound into the cabin and not reflect off the door panels and resonate inside the door. Looks ghetto, but it's functional and done proper. Remember this is a budget build and this foam wasn't purpose bought, it was scrap I had laying around.
OEM Cover back on the door. Only thing I didnt take a pic of was the panel re installed, but everyone knows what a stock door panel looks like.
Thank you for looking.
