Jeff4661 Posted February 4, 2015 Report Posted February 4, 2015 Found this gem earlier figured it was worth reposting here for our newer members.. Here is the official link http://www.pasmag.com/features/articles/3116-subwoofers-for-dummies but it's all below regardless Enjoy Subwoofers for Dummies Picking the perfect subwoofer for your system is as hard as picking the perfect car. Its a delicate balance of wants, needs and performance, and one that is best executed with the help of an experienced salesperson or installer. Lets take a look at the nitty gritty of what makes a subwoofer tick. Like a car, a subwoofer needs a chassis. These can be made of stamped steel, or on higher-priced models, cast aluminum. They are typically powder coated to provide a tough durable finish. And just as with a car, the stronger and stiffer the chassis (also called a basket) is, the better off you are. Some subwoofers have very heavy magnets, so a strong chassis that is able to withstand vibrations and stresses imposed as you drive down the street is critical. Attached to the base of the chassis is the motor. Yes, we call the magnet and associated parts the motor. It is half of what makes the speaker move. There are three parts to the motor assembly: The magnet, the top plate and the T-yoke. The top plate is a simple mild steel disc that sits on top of the magnet and focuses the magnetic energy on the voice coil. The magnet is of course the source of the magnetic field. The T-yoke focuses the magnetic field from the bottom of the magnet to the inside of the voice coil. The motor also needs to be able to help dissipate heat built up in the voice coil, so its design is critical. The cone assembly is comprised of four components: The cone itself, the surround, the spider at the base of the cone and the voice coil assembly. The cone can be made of paper, glass fiber, plastic or composites of many materials. Its job is to be light and rigid, and to transfer the motion generated by the voice coil assembly to the air to make sound. The voice coil assembly features a former made of aluminum or high-temperature plastics like Kapton, and a winding of copper or aluminum wire. The surround is a flexible connection at the top of the cone that allows the cone to move up and down. These are often pleated cloth, foam or rubber. The spider is the key suspension component of the woofer, though it works in conjunction with the surround to control the motion of the cone up and down. It also serves to keep the voice coil centered in the motor assembly so it doesnt rub. So, how does a speaker work? When you apply a voltage to the voice coil a magnetic field is created around the windings. This magnetic field either moves the voice coil away from the magnet, or pulls it closer to it. If, as with music, you alternate the polarity of the voltage applied to the voice coil, the speaker cone moves in and out, and voilà, music is made. A quick side-note speakers are made with single, double or quadruple voice coil windings. The windings can have different resistances (formally called impedance). No one design is any better than another, as they only exist to provide flexibility to the installer. Different wiring configurations (series or parallel) let the installer wire the subwoofers to make the amp produce different amounts of power. There are a set of about 20 parameters called Thiele-Small parameters that your installer can use to predict the behaviour of a subwoofer in different enclosures. Learning to balance enclosure designs to meet customer needs and desires is an art, and takes experience. Thats what we pay installers for. As with all speaker purchases, auditioning them is key. Take your favorite music down to your local car audio specialist shop and start listening. We could talk about subwoofers for this entire issue, but for now, its time to see whats available. Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
scooter99 Posted February 4, 2015 Report Posted February 4, 2015 Dang, looks like you stole my thunder. I didn't even see this and I just posted a thread about subwoofers. Sorry. Facebook Page: S99Creations 2006 F250 Lariat Build
Jeff4661 Posted February 5, 2015 Author Report Posted February 5, 2015 Dang, looks like you stole my thunder. I didn't even see this and I just posted a thread about subwoofers. Sorry.Which thread? Maybe we can combine them? After all were all in this together Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
scooter99 Posted February 5, 2015 Report Posted February 5, 2015 http://www.stevemeadedesigns.com/board/topic/195541-scooters-trying-to-boost-his-knowledge-trying-to-learn-some-ish-subwoofer-talk/ Hopefully you didn't take that wrong, yes we're in it together. I just mean I should've looked before I posted it. At least we're on the same page. Thanks! Facebook Page: S99Creations 2006 F250 Lariat Build
Krakin Posted February 5, 2015 Report Posted February 5, 2015 I just posted this on Scooter's thread, but I might as well repost here. I highly recommend reading up on AC circuits in this book. http://www.ibiblio.org/kuphaldt/electricCircuits/AC/AC.pdf And if you need some background you might want to start with the DC Circuits book. http://www.ibiblio.org/kuphaldt/electricCircuits/DC/DC.pdf This site has a lot of great stuff. http://www.subwoofer-builder.com/ http://www.silcom.com/~aludwig/ https://sites.google.com/site/amateuraudio/theory/compression One of the best sites I use. http://sound.westhost.com/articles.htm With this specifically dealing with T/S Parameters. http://sound.westhost.com/tsp.htm Have fun with the Germans. http://www.hifi-online.net/ http://www.physicsclassroom.com/class/sound/Lesson-5/Resonance One big ass book on Helmholtz Resonators (ported enclosures) https://books.google.com/books/reader?id=Xy4DAAAAQAAJ&printsec=frontcover&output=reader&pg=GBS.PA46 Small acoustics lessons http://www.trueaudio.com/st_spcs1.htm http://www.sonicdesign.se/optimum.html Best site I have for acoustic lessons and speaker lessons. http://www.linkwitzlab.com/publications.htm JBL Document http://www.pispeakers.com/ssdm_99.pdf Pi Speaker's Documents http://www.pispeakers.com/Speaker_Crossover.pdf http://www.pispeakers.com/Speaker_Crossover_Lab.pdf More Speaker Stuff http://www.stonessoundstudio.com.au/stone/diy_speaker_info/diy_introduction_p1.htm Diaphragm Materials Somewhat Explained http://www.stonessoundstudio.com.au/stone/diy_speaker_info/diy_driver_types_p3.htm Absorption coefficients of common building materials and finishes http://www.stonessoundstudio.com.au/stone/speaker_enclsoure_box_materials.htm Physco-Acoustics http://www.avforums.com/threads/sub-psychology.661795/ For the most detail about eddy currents in general: http://en.wikipedia.org/wiki/Eddy_current]http://en.wikipedia.org/wiki/Eddy_current]http://en.wikipedia.org/wiki/Eddy_current For the most detail about EMF: http://en.wikipedia.org/wiki/Electromotive_force]http://en.wikipedia.org/wiki/Electromotive_force]http://en.wikipedia.org/wiki/Electromotive_force Back EMF: http://en.wikipedia.org/wiki/Counter-electromotive_force]http://en.wikipedia.org/wiki/Counter-electromotive_force]http://en.wikipedia.org/wiki/Counter-electromotive_force The rest of these will be those and other things like impedance but in specific application: basic explanation and equations: http://physics.bu.edu/~duffy/py106/Electricgenerators.html]http://physics.bu.edu/~duffy/py106/Electricgenerators.html]http://physics.bu.edu/~duffy/py106/Electricgenerators.html More very basic explanations: http://www.prestonelectronics.com/audio/Impedance.htm]http://www.prestonelectronics.com/audio/Impedance.htm]http://www.prestonelectronics.com/audio/Impedance.htm This is a forum, but the guy answering knows his stuff so just double check anything you read but aren't sure about: http://physics.bu.edu/~duffy/py106/Electricgenerators.html]http://physics.bu.edu/~duffy/py106/Electricgenerators.html]http://physics.bu.edu/~duffy/py106/Electricgenerators.html https://www.boundless.com/physics/induction-ac-circuits-and-electrical-technologies/magnetic-flux-induction-and-faraday-s-law/back-emf-eddy-currents-and-magnetic-damping/]https://www.boundless.com/physics/induction-ac-circuits-and-electrical-technologies/magnetic-flux-induction-and-faraday-s-law/back-emf-eddy-currents-and-magnetic-damping/]https://www.boundless.com/physics/induction-ac-circuits-and-electrical-technologies/magnetic-flux-induction-and-faraday-s-law/back-emf-eddy-currents-and-magnetic-damping/ http://www.caraudiohelp.com/newsletter/speaker_impedance.htm]http://www.caraudiohelp.com/newsletter/speaker_impedance.htm]http://www.caraudiohelp.com/newsletter/speaker_impedance.htm http://sound.westhost.com/project56.htm]http://sound.westhost.com/project56.htm]http://sound.westhost.com/project56.htm http://sound.westhost.com/patd.htm]http://sound.westhost.com/patd.htm]http://sound.westhost.com/patd.htm http://en.wikipedia.org/wiki/Electrical_characteristics_of_dynamic_loudspeakers]http://en.wikipedia.org/wiki/Electrical_characteristics_of_dynamic_loudspeakers]http://en.wikipedia.org/wiki/Electrical_characteristics_of_dynamic_loudspeakers http://www.churchsoundcheck.com/imp1.html]http://www.churchsoundcheck.com/imp1.html]http://www.churchsoundcheck.com/imp1.html For your goals about designing, here are your 2 new best friends. http://sound.westhost.com/tsp.htm]http://sound.westhost.com/tsp.htm]http://sound.westhost.com/tsp.htm http://www.diy-audio.narod.ru/litr/FaradayRingsVoiceCoilImpedance.pdf]http://www.diy-audio.narod.ru/litr/FaradayRingsVoiceCoilImpedance.pdf]http://www.diy-audio.narod.ru/litr/FaradayRingsVoiceCoilImpedance.pdf A GREAT Book that is used by many Universities around the world. http://www.avatar.com.au/courses/PPofM/ Some more explaining boxes http://www.hometheaterhifi.com/volume_5_2/cmilleressayporting.html http://www.troelsgravesen.dk/vent_tuning.htm Transmission lines. http://www.t-linespeakers.org/design/MJK-for-dummies/index.html And the Handbook of OP-Amps. http://www.ti.com/lit/an/sboa092a/sboa092a.pdf Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Jeff4661 Posted February 5, 2015 Author Report Posted February 5, 2015 Beginning to look like a very useful thread.. *scooter99 I wonder if one of the threads will get pinned? This is a lot of information I might want to read up on later Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
