help me please enclosure issues
tryintoflex
It's custom to the sub (and checked through sofware), the figure is just an assembly guide but what is referred as port width is in the cutsheet referred as port height, the length of the internal wall is listed at the bottom of the cutsheet, basically all the parts you need to assemble are listed there and just need to be put together as shown in the figure.
Just make sure your cuts are clean and straight, most common issue is that parts don't fit very well together if not cut right and may result in leaks and other issues. If you haven't cut wood before, try to get someone to help you.
  • Who's Online   1 Member, 0 Anonymous, 2887 Guests (See full list)
