Box design For 2x Targas 1502dw's
BannisterEc
Hi
Wondering if anyone can help with a simple slot port design for 2 x Targa1502dw's 15" 2ohm Dvcs. Im looking to run them off 2000watts. My max length is 92cm(36.22 inches) x 55cm(21.65 inches) height x 100cm(39.37 inches) depth. Any help would be kindly appreciated.
The Specs are;
Fs 25.2
Spl(efficiency 1w/1m) 90.5db
Nominial impedance 1/2/4 ohm
Qts(total speaker "Q") 0.49
Qes(electrical "Q") 0.54
Qms(mechanical "Q") 5.27
VAS(equivalent compliance) 97.6L
Mounting Depth 18.8cm
Mounting Hole Diameter 35.5cm
Unfortunately those are the only specs I have
Post vehicle and amp if you have one, also a link (or whatever) to full specs of the subs. Also the wood thickness available in your country (usually 18mm).
Unfortunately I do not have anymore specs on the subs except what is in that printout. That amp looks similar internally to the Cactus k5 but the casing is slightly different, the board has different colouring and my remote is with the speaker terminals whereas the Cactus has the remote connected by the power connection terminals. The vehicle is a 2006 Fiat Palio Panelvan 1.2i. I will try upload pics of the speaker and car
That's good enough, no problem, just let me know the thickness of the wood you have available.
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 14 cm, figure is just an assembly guide:
Note: Your amplifier may be too much power for those subs so take care with that.
  • Who's Online   0 Members, 0 Anonymous, 2967 Guests (See full list)
