subwoofer single 6 ohm wiring diagram
Is there any good subwoofer wiring diagrams. I tried looking online but found mostly dual 6 ohm, and the common SVC 2 or SVC 4, or DVC 2 and DVC 4, but single 6 ohm is hard to find. I'm trying to run a small project and running two single 6 ohm 8" subs, and I don't want to fry my amp by wiring it up wrong. I'm running an alpine pdx 600 and it has 2 or 4 ohm load.
Wire them in parallel. The positive of one sub to the positive of the next sub to the positive of the amp.
The negative of one sub to the negative of the next sub to the negative of the amp.
Your amp will see a 3 ohm load, which is fine. The lowest your amp can handle is 2 ohms, but it can also handle any ohm load higher than that. The specs only show 2 and 4 ohms because those are the most common.
Seriously even after the section was moved you still posted in the wrong section
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
