(2) Kicker vx 12's Dual 4ohm and a Audiopipe 30001d
Ruben0987
I'm not even sure where to begin I bought a new amp for my subs for ($82)!! Audiopipe 30001d and it was all still in the plastic my Kicker vx are rated at 750rms 1500w Peak should I wire them at 1-4 Ohm because 1 Ohm will blow my subwoofer if I should wire them at 4ohms can someone please explain how to wire it and connect it to this amp that has to connections cause it 2-1500 straped
Thanks I'm kinda a noob at this stuff as you can see
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
did your mommy and daddy not give you enough attention when you were a kid?
jesus fucking christ. YOU HOOK THE RED WIRE TO THE POSITIVE AND THE BLACK WIRE TO THE NEGATIVE. theres two outputs per terminal for sake of having more connection points, they are paralleled so it doesnt matter which terminal is used for pos and neg
Brandon
System:
2001 2 door focus
1 DD9918 SC
I'm being a dick because you are spamming the forum before allowing any time for people to respond. chill the fuck out for a minute before you get banned by N8.
there are two pos terminals and two neg terminals. they are both paralleled. so what that means is you can put your positive lead in either pos terminal and the same for the neg, they dont have to be both filled. The amp is strapped internally so dont worry about that, and those amps are only stable down to 2 ohm nominal on the outputs, so wire to 4 ohm as shown in the diagram and go from there
Brandon
System:
2001 2 door focus
1 DD9918 SC
  • Who's Online   1 Member, 0 Anonymous, 787 Guests (See full list)
