vitochelopez Posted February 9, 2015 Report Posted February 9, 2015 Is there really a difference in your SQ in using different RCA's? I currently use the Scosche twisted entry series. Now would going to a more expensive or different set change anything audible as far as the SQ?
Ahmed Johnson Posted February 9, 2015 Report Posted February 9, 2015 Are you hearing any noises? I have some cheap ones and some decent ones in my car now and they work fine. The only rca's that ever gave me a problem was the unshielded ones, that were see through.
vitochelopez Posted February 9, 2015 Author Report Posted February 9, 2015 Yes I was getting major engine noise, and I placed some RCA filters and now its gone. I do have my power wires and RCA wires on separate sides of car. Not sure if its just the RCA's? They are the see through ones from Scosche.
Ahmed Johnson Posted February 9, 2015 Report Posted February 9, 2015 It could be a ground causing that. Other than the non shielded rca's, the only time I heard a whining noise was from a bad ground. When my rca's went bad, I would hear a crackling noise. Not sure if this helps you.
YukonDCXL Posted February 9, 2015 Report Posted February 9, 2015 Are you sure your amp calls for the twisted rcas? most don't... D'amore has a video on youtube explaining
vitochelopez Posted February 9, 2015 Author Report Posted February 9, 2015 Are you sure your amp calls for the twisted rcas? most don't... D'amore has a video on youtube explaining What do you mean by does my amp call for them? Cant you use any RCA's meant for car audio? And I have changed my amp brand twice with slight upgrades and the noise was still there.
aculous Posted February 9, 2015 Report Posted February 9, 2015 I've been researching RCAs. Really the high quality the better. The SMD RCAs are really nice but yea twisted or not you need to check which you need. Also look for capacitance and resistance in the cable. A good cable with have ultra low resistance and low capacitance. Low capacitance meaning 17 pF or pico farads per foot. Thats probably more then you need to worry about...but yea look for cables that actually list those figures, chances are you are getting a cable someone engineered as opposed to cobbled together and will break easy.
aculous Posted February 9, 2015 Report Posted February 9, 2015 Are you sure your amp calls for the twisted rcas? most don't... D'amore has a video on youtube explaining What do you mean by does my amp call for them? Cant you use any RCA's meant for car audio? And I have changed my amp brand twice with slight upgrades and the noise was still there. thats an electrical issue...check your grounds. Its not your amp or RCAs
vitochelopez Posted February 9, 2015 Author Report Posted February 9, 2015 Wow very good youtube video and very good info that I never knew. Only problem is I have no Idea what kind my amp has?! It is a Lanzar Optidrive
