number of ports vs lengh
guimond47
right now i have it set up like picture 2 . one inverted and the other is normal. they are type X tho. these are type R's back in the day lol....
i was gotta add 2 more 90* on top of the ones i got going on and have lengh of tube added to 4 of them, approx 25"...
Do you have one of the subs wired out of phase? Meaning 1 normal and 1 with the pos & neg reversed. If both are normal or both inverted then it doesnt matter but one each way it does
01 Chevy Silverado X-cab
2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's.
2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp.
Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage.
96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time.
Yes one sub is reverse polarity. Like its loud now after setting the gains with oscilloscope. But would it be louder with more port area
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
I throw about 2200watt rms on a daily basis . Clean signal no clip
Bump
  • Who's Online   0 Members, 0 Anonymous, 1279 Guests (See full list)
