Go-N-Def Posted February 12, 2015 Report Posted February 12, 2015 Are relays needed for every component?(Eq,Amp1,Amp2) What are the for? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
jk13 Posted February 12, 2015 Report Posted February 12, 2015 For turn on? One relay total. I use one anytime there are more than two components to trigger on. Takes the load off the deck's turn on circuit. Some amps/eqs/etc. pull more than others and it's just safer to put a relay in than to risk damaging the deck. Static drops are my bag.
Go-N-Def Posted February 12, 2015 Author Report Posted February 12, 2015 Great. So currently I have one to make my DVD active then it leads to the amp is that ok? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Go-N-Def Posted February 12, 2015 Author Report Posted February 12, 2015 I didn't see the thread above till late. Where do you get the power for the relay? I'm currently tapping into the head unit power. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
jk13 Posted February 12, 2015 Report Posted February 12, 2015 Usually at the amp rack rather than stuffing it behind the radio. Serviceability and space. Static drops are my bag.
Go-N-Def Posted February 12, 2015 Author Report Posted February 12, 2015 I'm using it originally to activate my dvd. It that ok for the dvd bypass and amps Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
