Sub shopping with limited space (noob)
Eggs
Hi, A noob need input. Wondering if a 15 DSS trident (same spec as Ethos) will fit in my trunk 31"W 17"H 21ish"D. And it would be cool if someone design a simple slot ported box @33hz-ish? That manufacture specs are below. Thank you.
Ported
Volume: 3.0ft^3
Tuning: 32 hz
Port Area: 75in^2
Ripple: 5 db
F3: 28 hz
Using your dimensions 31x17x21, gives you 6.4cf of truck space.
Now before you go any further, you will need to see how much room you have to "put the box in the trunk".
Once the trunk lid goes up, the only restriction will be the top of the trunk, the bottom of the trunk,...and if you have a Bimmer, the sides sides of the trunk!
Put it this way, I had originally had,.. say 33x16x21 of space to work with. With that damn trunk opening, I had to bring the box down to 28x13x17 or so. Something like that.
Because there was not way of building a 29" long box, if the opening is only 28"!
Just keep things like this in mind before asking for someone to build you a box....it may not fit the trunk opening.
Get empty cardboard boxes from Walmart, and test what boxes will fix. Cut, tape a box-to-a-box to simulate a 3.5cf enclosure.
1800W sub?? (shaking my head).
-Frank
It's definitely doable OP just get dimensions that you can fit through the trunk opening if this is going to a trunk car. Post them on here one you have them.
  • Who's Online   1 Member, 0 Anonymous, 5311 Guests (See full list)
