crownvictoria31 Posted February 17, 2015 Report Posted February 17, 2015 Need help on selecting a amp that is going to give me great power at a decent price. I have 4 10" crescendo pwx10 on my rear deck and 2 6" on front doors. So its a total of 6 speakers. I also have some tweeters but I already have a nice amp for those. The crescendos 10" are 4ohms each and the front speakers are seleniums 8ohms. Any really good amps for a decent price that will push these mids hard?
crownvictoria31 Posted February 19, 2015 Author Report Posted February 19, 2015 can anyone recommend a good budget amp for these? My cousin has a mb quart onx125.4, will this work out?
moredbs Posted February 20, 2015 Report Posted February 20, 2015 why not get a 4 channel crescendo amp? they are budget friendly,and put out.
crownvictoria31 Posted February 20, 2015 Author Report Posted February 20, 2015 why not get a 4 channel crescendo amp? they are budget friendly,and put out. I was checking them out. How would i connect 6 speakers there.
islandpride684 Posted February 20, 2015 Report Posted February 20, 2015 why not get a 4 channel crescendo amp? they are budget friendly,and put out.I was checking them out. How would i connect 6 speakers there. You don't Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
crownvictoria31 Posted February 20, 2015 Author Report Posted February 20, 2015 So one crescendo per channel and im done? As per the door speakers, guess ill have tofigure that out.
islandpride684 Posted February 20, 2015 Report Posted February 20, 2015 So one crescendo per channel and im done? As per the door speakers, guess ill have tofigure that out. If I were to do it, I would get the 1100.4 and wire the 6s on the first two channels and then wire the 10s on the last two channels So for the 10s, wire 2 of them in parallel then wire to amp on ch 3 and wire the next set the same then wire to ch 4 of the amp...so each 10s will see about 150 rms... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
crownvictoria31 Posted February 21, 2015 Author Report Posted February 21, 2015 Are hifonics amp any good? I mean, ive had a few in the past for subs and had no problems and they did what they suppose to do. specs are as followed: Hifonics BRX1200 4 Brutus Series 4-Channel Super AB Class Car Amplifier RMS Power Rating: 4 ohms: 150 watts x 4 chan. 2 ohms: 300 watts x 4 chan. Bridged, 4 ohms: 600 watts x 2 chan. Ultra-Fi MOSFETS Circuit maximizing power efficiency while improving sound quality Wired remote bass level control available and sold separately (Hifonics HFR3) LED power (green) and protect (red) indicators Variable Bass Boost (0 to +10 dB bass boost) Built-in system diagnostics 4/3/2/1 Channel operation Preamp RCA outputs to daisy chain multiple amps 3-way protection circuitry (thermal, overload, and speaker short protection) Heavy duty aluminum alloy heat-sink with illuminated Hifonics logo Lighted connectors and blue wash of light from the underside of the heatsink Input sensitivity: Level: 200mV-6V Variable high-pass filter (10-1,500 Hz) Variable low-pass filter (30-150 Hz) Frequency response: 10-45,000 Hz CEA-2006 compliant amplifier Dimensions: 24-7/16"L x 10-5/16"W x 2-1/2"H Seems to do the same as the crescendo but for less the price. http://www.ebay.com/itm/HIFONICS-BRX1200-4-BRUTUS-AMP-4-CHANNEL-2400W-MAX-COMPONENT-SPEAKERS-AMPLIFIER-/121159094300?pt=LH_DefaultDomain_0&hash=item1c35a5101c&vxp=mtr
crownvictoria31 Posted February 21, 2015 Author Report Posted February 21, 2015 also theres this other one claiming to do same as crescendo? Hifonics X1200 4 brutus Series X14 4-Channel Car Amplifier RMS Power Rating: 4 ohms: 150 watts x 4 chan. 2 ohms: 300 watts x 4 chan. Bridged, 4 ohms: 600 watts x 2 chan. Max power output: 600 watts x 4 chan. Illuminated Hifonics badge DC, short circuit, thermal, and overload protection Wired remote bass level control included Variable Bass Boost (0 to +10 dB bass boost) 4/3/2 or Mono channel operation Speaker-level (high-level) inputs with signal sensing for automatic turn-on Variable high-pass filter (10-2,500 Hz, 24 dB/octave) Variable low-pass filter (35-2,500 Hz, 24 dB/octave) Dimensions LxHxW: 18.82" x 2.5" x 9.49" amp looks beefy to. 2 60amp fuse http://www.ebay.com/itm/121342207355?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
moredbs Posted February 21, 2015 Report Posted February 21, 2015 also theres this other one claiming to do same as crescendo? Hifonics X1200 4 brutus Series X14 4-Channel Car Amplifier RMS Power Rating: 4 ohms: 150 watts x 4 chan. 2 ohms: 300 watts x 4 chan. Bridged, 4 ohms: 600 watts x 2 chan. Max power output: 600 watts x 4 chan. Illuminated Hifonics badge DC, short circuit, thermal, and overload protection Wired remote bass level control included Variable Bass Boost (0 to +10 dB bass boost) 4/3/2 or Mono channel operation Speaker-level (high-level) inputs with signal sensing for automatic turn-on Variable high-pass filter (10-2,500 Hz, 24 dB/octave) Variable low-pass filter (35-2,500 Hz, 24 dB/octave) Dimensions LxHxW: 18.82" x 2.5" x 9.49" amp looks beefy to. 2 60amp fuse http://www.ebay.com/itm/121342207355?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT no, don't do it. i once thought i could get away with running a hifonics amp on my mids and highs for cheap so i bought one. It sucked, i had a jbl amp that was rated half of the hifonics rms and it sounded louder and better, but its your money.
