djcue12369 Posted February 18, 2015 Report Posted February 18, 2015 I have a 1996 honda accord.... putting in a audiopipe txx bd3 single 10 inch duel 2 ohm sub. I wanted to go with a ported design with a big port if possible..... dimension are 32/w...17/d.....14/h... will be powering it will hifonics 1200.1 @ 1 ohm... not going to be running it hard all the time just a daily driver...any help would be great thanks guys...
firebirdude Posted February 18, 2015 Report Posted February 18, 2015 So what more help do you need? Need me to pass the jigsaw and wood glue?
djcue12369 Posted February 18, 2015 Author Report Posted February 18, 2015 uh, no I was asking help on dimension for the subwoofer enclosure so I could build it... seeing as though i'm not to good at designing enclosures
Joe X Posted February 18, 2015 Report Posted February 18, 2015 Here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 1 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
djcue12369 Posted February 18, 2015 Author Report Posted February 18, 2015 Hey Joe...thanks for the design looks great as always... Can the port be a little bigger?
djcue12369 Posted February 19, 2015 Author Report Posted February 19, 2015 going to start on this this weekend
Bryan88 Posted November 7, 2015 Report Posted November 7, 2015 any updates on this enclouser? did you built it?
