DC Level 3 12"
AndersNorlev
Those dimensions are not nearly enough for a dc level 3
Im getting around 1.5cu ft with those measurements
you need to be close to 3.3 cu ft
Hello,
Im lost.... I have tried to build a enclosure for my lvl3 12" and all online calculators makes different measurements..
I have a buddy and he sad i need a box in, 400x660x280mm with a vent at 70mm...
Can some one help me??
//Anders
Here is a suggestion on low power, upgrade to a 1K amp when possible, made for 18mm 19mm wood, if different thickness is needed, let me know:
NOTES: power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 7 cm, figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Changed to 19mm so that your parts fit perfectly as possible, a single mm made enough difference to require some changes to preserve the original spec. All done now, have fun.
  • Who's Online   0 Members, 0 Anonymous, 4888 Guests (See full list)
