krazz619 Posted March 15, 2015 Report Posted March 15, 2015 Hey guys, So I will be getting a single SQ HDS312 soon and trying to figure out box dimensions so I can make one for it, It's going in a trunk car Max Dimensions, LxHxD 40x14x21 Kinda trying to get around 2 cubes and maybe 35-38hz The smaller the box the better so I can reuse the box in any vehicle. Thanks ahead of time, much appreciated. 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
Joe X Posted March 15, 2015 Report Posted March 15, 2015 Here is a suggestion, should fit many trunks, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
krazz619 Posted March 15, 2015 Author Report Posted March 15, 2015 Awesome, perfect. I'll save this, dummy test it, and possibly make it. Thanks Joe X Quick question, How do I decide where I cut the hole for the sub? Is there specific measurement or whatever i think looks best? 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
Joe X Posted March 15, 2015 Report Posted March 15, 2015 Best is as far away from the inner end of the port as possible but not critical in this case, if you like it in the center of the baffle, you could do that.
krazz619 Posted March 16, 2015 Author Report Posted March 16, 2015 Another question, if I sand the corners of the port, that won't change the like specifications will it? 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
Joe X Posted March 16, 2015 Report Posted March 16, 2015 Here's how to do the 45s: Done like this the difference in net volume would be about 0,01 cubic feet, no discernible difference.
krazz619 Posted March 17, 2015 Author Report Posted March 17, 2015 Ok thanks, what about rounding the edge of the port extension so its all smooth and no corners? Basically is it worth it for this situation or no? 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
krazz619 Posted April 12, 2015 Author Report Posted April 12, 2015 Real quick, would 2-1/2 drywall screws be too long for this? Edit: also I'm curious about if I should use different screws for the sub, and should screws ever pretrude through the other side so you can see the end inside the box or no? 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
Joe X Posted April 13, 2015 Report Posted April 13, 2015 I wouldn't recommend those long screws nor too many of them just enough to have the parts dry in place. You can use different screws for the subs any way you want as long as there are no leaks.
