Nate121 Posted March 17, 2015 Report Posted March 17, 2015 So, I'm trying to see if I can build a box inside of my trunk. Or something. The clearance I have is shotty. At one point I have about 14.5 on the height 14.5 on the depth. and around 30 in for the width. Maybe a little less. Any help on this? I have no clue on how to vent a box which I would like to do at around 35hz.
Joe X Posted March 17, 2015 Report Posted March 17, 2015 Welcome, here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Nate121 Posted March 17, 2015 Author Report Posted March 17, 2015 Wow. Thanks man. I've heard these subs are greatly underrated. Should I just throw 600 RMS at it? Or should I Bump it up a little and tweak the gain etc.
Joe X Posted March 17, 2015 Report Posted March 17, 2015 If you know your stuff you can do well above rated but then you would gain some 2dB or so doing it, if you have the skills and think is worth it go for it.
effect Posted March 28, 2015 Report Posted March 28, 2015 Hi Joe I will be running that same sub an sa12 In a 4 door civic 2015 will this box design. Work well having it face the trunk? Thanks in advance
Joe X Posted March 29, 2015 Report Posted March 29, 2015 If it fits and the tuning is to your taste it should work well for you.
effect Posted March 29, 2015 Report Posted March 29, 2015 Thanks Joe. Just going on what sa recommends lol how much port area is this design?
effect Posted March 29, 2015 Report Posted March 29, 2015 Thank you . can't wait to build it. See how it sounds
