Question for Joe X
EddieC
Joe, I have a quick question about an enclosure design you did for me. It's at this link.
http://www.stevemeadedesigns.com/board/topic/195844-opinions-suggestions-for-single-12-ethos-design/#entry2939440
Question is...do I need to add any bracing for this or will the double baffle be enough support? I asked this in another post but you didn't reply so I don't know if you saw it or not. On that thread I had someone tell me that they would do a 1" dowel on each side of the sub from the front to the back, going through the port. I did have some 45s cut for each of the corners to help with support, but I don't want to add too much and screw up the tuning. Also, on the double baffle both sub cutouts are the same, so there will not be a flush mount. I'm kinda thinking. ..and hoping, that will be enough. What do you think?
And thanks again for the design man. I'm using one of yours right now on 2 SSA DCON 12s and that thing pounds HARD for such low powered subs. Thanks for that one too! You obviously know your shizz!
Current install:
Pioneer DEH-X8600BH HU
AQ200.2 front stage amp
Q1-2200.1 sub amp
2 12" SSA DCON subs in 4cu ported tuned to 32 Hz
Image Dynamics CTX65 drivers
Image Dynamics XS28 tweeters
Kicker DS40 dash speakers
KnuConcepts 4 gauge wiring for AQ200.2
1/0 OFC big 3 and rear battery/sub amp runs
220 amp HO alt from Js Ultimate Alts
Second Skin Damplifier Pro deadening
Optima Yellow Top Group 34 / 78 under hood
Die Hard Platinum Group 31 marine in rear
Stinger voltmeter
Please use pms.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 5219 Guests (See full list)
