Gregory Brissitt Posted March 25, 2015 Author Report Posted March 25, 2015 If those are exactly what you got they are 2 ohm voice coil subs. It is not possible to wire up two 2 ohm dual voice coil subs to 2 ohms final load. This isn't a problem, you just need to keep it in mind when you pick an amp. thats exactly what i have,,,, and thats y i am in the hunt for a good enough amps to play these subs... as for the final install like the connecting of the speaker and amps etc , i am going to ask a guy that install audio to do so for me ,i just want to be there to see what he is doing and to correct him if i see something going wrong , thats y i am trying to get as much info here and to learn as well so i can have an idea of whats going on , i dont want to spend money buying stuff and then someone fuck it up because they dont know what they doing,, so all the help i can get i will take and make the best of it
reedal Posted March 30, 2015 Report Posted March 30, 2015 If those are exactly what you got they are 2 ohm voice coil subs. It is not possible to wire up two 2 ohm dual voice coil subs to 2 ohms final load. This isn't a problem, you just need to keep it in mind when you pick an amp. Say what? I'm pretty sure two 2ohm dvc subs can be wired as .5, 2, and 8 ohm final impedances. Because that's exactly what I did with my two 2ohm dvc hds312's, is wire them a 2ohm final impedance. http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=2&I=22#results So OP should wire to two ohm, meaning for full use of RMS of subs, find an amp that does ~2400W at 2ohms. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Triticum Agricolam Posted March 30, 2015 Report Posted March 30, 2015 If those are exactly what you got they are 2 ohm voice coil subs. It is not possible to wire up two 2 ohm dual voice coil subs to 2 ohms final load. This isn't a problem, you just need to keep it in mind when you pick an amp. Say what? I'm pretty sure two 2ohm dvc subs can be wired as .5, 2, and 8 ohm final impedances. Because that's exactly what I did with my two 2ohm dvc hds312's, is wire them a 2ohm final impedance. http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=2&I=22#results So OP should wire to two ohm, meaning for full use of RMS of subs, find an amp that does ~2400W at 2ohms. Yeah you are right. I had a brain fart. I was thinking it is not possible to wire up two 2 ohv DVC subs to 1 ohm final load. I've edited my post to reflect this. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Gregory Brissitt Posted March 31, 2015 Author Report Posted March 31, 2015 ok so if i am using one amps.find one that do around 2400w at 2 ohms ok,,, what if i want to use two apps to play both subs. eg. two of these ,,, how would i wire them to play Rockford Fosgate Prime 1,200-Watt Class-D
Triticum Agricolam Posted March 31, 2015 Report Posted March 31, 2015 ok so if i am using one amps.find one that do around 2400w at 2 ohms ok,,, what if i want to use two apps to play both subs. eg. two of these ,,, how would i wire them to play Rockford Fosgate Prime 1,200-Watt Class-D You could wire each sub to 1 ohm (both coils in parallel) and then wire from one sub to one amp and the other sub to the other amp. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Gregory Brissitt Posted April 1, 2015 Author Report Posted April 1, 2015 this is how far i reach all i am waiting on now is the 2 RF prime 1200 d
