sencheezy Posted March 30, 2015 Report Posted March 30, 2015 just go with regular ported 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy
Hugh G. Rection Posted March 31, 2015 Report Posted March 31, 2015 If wanna do something different, then just dive off into a rear loaded horn. Owner of BigAss Ports
mrd6 Posted March 31, 2015 Report Posted March 31, 2015 ...I don't know I'd any calculators or design programs that will model a series tuned 6th order but winisd does well for 4ths and parallel 6ths.Hornresp can kinda model series tuned BP6 boxes. Akabak can definitely do it. Both programs are free, but both require you to really know what you are doing to get good info out of them, ESPECIALLY Akabak. No kidding? I'll have to check those out! My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
Triticum Agricolam Posted March 31, 2015 Report Posted March 31, 2015 No kidding? I'll have to check those out! Just so you are prepared, Hornresp isn't too tough to use, but it works quite a bit differently than other programs you may be more used to (like WinISD). Here is a how to guide for Hornresp that will get you going: http://www.hometheatershack.com/forums/diy-subwoofers-general-discussion/36532-hornresp-dum-hmm-everyone.html Akabak, on the other hand, has a significantly steeper learning curve. I'm just beginning to learn to use it myself and I still have almost no idea what I'm doing. The other problem is it will NOT run under a 64-bit OS, at all. I'm running under WinXP in a 32-bit virtual machine on my Win7 64-bit desktop PC. It works, but it was a bit of a hassle to setup. The advantage of Akabak is you can model just about anything. 8th order bandpass boxes, very complex horns, anything you can think of. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
