DC Audio 2.0K Or 3.5K
Zendejas
Currently have two Alpine Type R Current Generation. Had low funds at the time so bought budget Amp Interfire Digital Amplifier T-3000D .
Have XS Power D3400. Secondary Battery is been shipped.And ran Knu Konceptz 0 Gauge Wire. Witch would be the best amp For the Type R's 2.0K Or 3.5K
Model No. RMS
T-3000D Channel 1ch Mono Total Max Power 3000 watts 4 Ohm at 14.4V 0.3%THD ( RMS ) 400w x 1ch 4 Ohm at 14.4V ( MAX ) 700w x 1ch 2 Ohm at 14.4V 0.3%THD ( RMS ) 750w x 1ch 2 Ohm at 14.4V ( MAX ) 1500w x 1ch 1 Ohm at 14.4V 0.3%THD 3000W Mono Bridge ( RMS ) N/A Power Supply Full PWM Output Power Circuit Configuration Class D Miscellaneous Spec Damping Factor @ 4 Ohms / 100Hz >150 S/N Ratio(A-Weight) >90dB THD <0.1% Miscellaneous Spec Crossover S/W for 1+2 channel 12dB/Oct. N/A Variable Hi-Pass N/A Variable Low-Pass 50Hz - 250Hz Bass Boost, 12dB @ 45 Hz Yes Others Dimension (Lmm x Wmm x Hmm) 12.8"x10"x21/8"
Well the 2000 will better suit the subs even though they would still be double over powered unless you set gains conservative. The 3500 would leave room for upgrade in the future. The 3500 is not cheap. Most importantly is to set your gains correctly. Those subs are 500 watts RMS rating so the 2000 is great plenty.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Getting the Mayhem's by June Would 3.5K be Optimal for them And the Type R's are the Newest Version SWR-12D4
Power Range: 250W - 1000 Watts
RMS Power Handling: 1000W
Peak Power Handling: 3000W
1000 watt subs would still work great off the DC Audio 2.0, If you get the 3.5 it still leaves you room to upgrade the sub stage to either more 10s or bigger subs later down the road
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
If your getting AA Mayhem by June I would go with a 3.5k now and another in june. Along with a few good large batteries and 1 or 2 alternators.
Or just get a 5k, I'm guessing there D4 coil type r so run them at 4 ohms for now.
  • Who's Online   1 Member, 0 Anonymous, 632 Guests (See full list)
