Jessica Posted April 12, 2015 Report Posted April 12, 2015 Anyone else remember when amps had a switch to select your ohm load? i remember my brothers old kenwoods had them and i thought some RF amps had a board in side you would adjust dip switches or something(never owned one) and my grandfather gave me a tube amp that had a 8/16/24 ohm load selector on the back. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ALPINE408 Posted April 12, 2015 Report Posted April 12, 2015 Never seen it.... The fosgate chips where cross over adjustments... I've owned them before my friend still has some Have you ever had your woofers blown?
Colin - STAPUFT Posted April 13, 2015 Report Posted April 13, 2015 I *think* the Linear Power amps have one or something like that, but inside the amp? 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back.
Johnny2Bad Posted April 16, 2015 Report Posted April 16, 2015 There is really no point to an output impedance switch on a Solid State power amplifier, but I can see it being part of a crude protection scheme (adding a power resistor for safety sake) which basically means a poor or budget design. Vacuum State amplifiers put out the most power when the output transformer and the load are well matched in impedance, but less power if the output transformer's impedance and the speaker impedance are poorly matched. As long as the impedance is matched, a Tube amp puts out the same power into any load. So you would want to use the 4 ohm tap with 4 ohm speakers (for example) on a tube amp for best power delivery, and it's common for a tube amp to have multiple taps (4,8 and sometimes 16 ohm). Properly hooked up, a tube amp rated at (for example) 20 watts it would be 20 watts into 4, 8, or 16 ohms if it had all three taps. Note that there is such a thing as a transformer-coupled output state in a Solid State amp, but it's rare, found mostly on 1960's gear. Note also that we are referring to impedance taps on the output transformer, not the actual measured output impedance (which is relatively high in tube amps but generally lower than 1 ohm).
RooTxBeeR Posted April 16, 2015 Report Posted April 16, 2015 Class has started, and I don't have a pencil. How many more lessons? lol good info man. That could be a cool feature. You just plug up all the +/- off the subs to the amp and just select eh ohm load or something? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
