Stereo Integrity MAG v3 12s..box design ideas
I just ordered two of the new Stereo Integrity MAG v3 12s. I am putting them in an expedition powered for the time by a Sound stream Tarantula nano 1200 (may upgrade this). I cant decide on box size or tune. I am thinking 3.5 cubes to 31hz. Port size? Thanks.
Also, does anyone know if these are dual voice coil? If so, what the impedance is of each coil?
Specs from SI below
  • Foam surround
  • 3″ aluminum voice coil
  • 1000 watts RMS power handling
  • Aluminum magnet ID shorting ring
  • Chrome motor finish
  • Cast aluminum basket
  • Dual 8″ polycotton spiders with flat sewn-on leads
  • Large 4 AWG speaker terminals
  • 28mm one-way linear Xmax
NEED TO UPDATE
  • Cutout: 11.2″
  • Outer Diameter: 12.5″
  • Mounting depth: 6.75″
Mag v3 Re 3.4 ohms Fs 30 Hz Qes 0.42 Qms 3.44 Qts 0.38 Le 2.4 mH Sd 480 cm^2 Vas 40.4 L BL 19.3 Mms 240.1 g Xmax (1-way) 28 mm Xmech (1-way) 32 mm
Looks they are single voice coil (4 ohm) and have an Le of 2.4 mH.
Should be really nice subs.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 4706 Guests (See full list)
