buff_n3rd Posted April 27, 2015 Author Report Posted April 27, 2015 I'm open to suggestions on the amp. If its possible to keep it under 400 that would be great. I want to do it right, probably my only real concern. If it costs more I'll budget for it.
TortoiseShore Posted April 27, 2015 Report Posted April 27, 2015 I'm open to suggestions on the amp. If its possible to keep it under 400 that would be great. I want to do it right, probably my only real concern. If it costs more I'll budget for it. http://www.stevemeadedesigns.com/board/topic/197632-aq-2200-350-shipped-and-insured/#entry2975685that's what I would go with. Fits your budget, and give you plenty of lower to work with
Joe X Posted April 27, 2015 Report Posted April 27, 2015 The Soundqubed Q1-2200.2 is $429, if you just want to push rated Soundqubed Q1-1200.2D is only $269 both good and efficient amps.
TortoiseShore Posted April 27, 2015 Report Posted April 27, 2015 I prefer to buy newUnderstandable. There are plenty around your price range. Scv1500 is a little over, the aq 1200 or 2200, and the crescendo s1500 are the first That come to mind
Joe X Posted April 27, 2015 Report Posted April 27, 2015 For a box it can be something like this: But I would need some dimensions to work with and power you plan to run.
buff_n3rd Posted April 27, 2015 Author Report Posted April 27, 2015 Well the $400 point was just to keep me from looking at a $1500 amp. If its $400 +/- $200 I can justify. If that amp is the best recommended at the price point to fully run it then I am all for it. Box dimensions I am looking at are as follows 42w x 18h x 32d the very first post has a picture of my cargo area. Thanks Joe. I've seen many of your renderings and they are always top notch.
Joe X Posted April 27, 2015 Report Posted April 27, 2015 There are many amps, those two above are quite good, the BC2000 would be another option, if you want more expensive you can pick DC Audio, Sundown..etc. Here is a suggestion for the box aimed for the lows, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide:
jroo Posted April 28, 2015 Report Posted April 28, 2015 I can PM you a 4th order design for a sa12. I got it from another member/forum. I am going to build it in the next few months. The SA has a big peak around tuning in the 32 to 33 tuning range. If you want loud, many are correct that the SA will get loud in a standard ported box.
buff_n3rd Posted April 28, 2015 Author Report Posted April 28, 2015 There are many amps, those two above are quite good, the BC2000 would be another option, if you want more expensive you can pick DC Audio, Sundown..etc. Here is a suggestion for the box aimed for the lows, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/4", figure is just an assembly guide: Hey Joe. It appears the pics disappeared. Would I be able to get those again. I don't think I had them saved just yet. Thank you.
