Cbarnett_2500 Posted May 5, 2015 Report Posted May 5, 2015 Hey fellas. At the moment, I have 2 blown DX-15 American Bass subs. I'd like to rebuild/recone them with better parts and convert them from a single 4 ohm coil to a dual 2 ohm coil. I've found all the parts I need, but I'd like some help determining the amount of power I might be able to put through them. Currently, the stock coils can take up to 500 RMS and 1000 peak. I'd like to try and achieve more than that, otherwise, I might scrap the subs. Here's the link to the voice coil I'm installing. Let me know what they might be able to achieve, or how I can calculate what amount of power will work. http://shop.subwooferparts.com/product.sc?productId=321 Thanks guys!
MrBigs63' Posted May 5, 2015 Report Posted May 5, 2015 I wouldn't want to run more than 1k rms to a 2.5in coil. It can be done, but over 1k is really pushing it imo. But hey I know nothing about sub building. Someone a little more experienced like audiofanaticz or some of the other sub builders here may chime in later.
Cbarnett_2500 Posted May 5, 2015 Author Report Posted May 5, 2015 I wouldn't want to run more than 1k rms to a 2.5in coil. It can be done, but over 1k is really pushing it imo. But hey I know nothing about sub building. Someone a little more experienced like audiofanaticz or some of the other sub builders here may chime in later. I just want something that will hit at least 500 rms or a bit more. I don't want to buy the dang thing, spend a couple days building it, and only achieve 400 rms or something lol.
MrBigs63' Posted May 5, 2015 Report Posted May 5, 2015 Well you said that you want to achieve higher than 500 rms. A quality flatwound 2.5 inch coil should be able to handle from 500-750 no problem. Like I said you could go up to 1k but that is kind of pushing it. The coil is only a small part of determining power handling. You need to take things like the suspension and cooling into account. Have you ever built a recone before? If you haven't I would recommend contacting PSI to build you a recone. You can tell them the specifics of your woofer and what you want to accomplish, and he will build a recone to suit your needs.
Cbarnett_2500 Posted May 5, 2015 Author Report Posted May 5, 2015 Well you said that you want to achieve higher than 500 rms. A quality flatwound 2.5 inch coil should be able to handle from 500-750 no problem. Like I said you could go up to 1k but that is kind of pushing it. The coil is only a small part of determining power handling. You need to take things like the suspension and cooling into account. Have you ever built a recone before? If you haven't I would recommend contacting PSI to build you a recone. You can tell them the specifics of your woofer and what you want to accomplish, and he will build a recone to suit your needs. I haven't rebuilt them before. I've looked into PSI rebuilds, but would very much like to do it myself. I got the subs for free (traded for them), so I'd like to experiment on them before moving onto different things. As long as I can get at least 500 rms, I'll be good. Thanks for the help!
