MrSevs Posted May 6, 2015 Author Report Posted May 6, 2015 Never mind. There's even a sundownbox on their site, if it fits you are good to go. Thanks Joe X. I will take a look at it and let you know.
Joe X Posted May 6, 2015 Report Posted May 6, 2015 Here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6 3/8", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Joe X Posted May 9, 2015 Report Posted May 9, 2015 As per your request here's the port on the side version, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6 3/8", figure is just an assembly guide, bracing is 1 1/4" wooden dowel rods:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
MrSevs Posted May 10, 2015 Author Report Posted May 10, 2015 Thanks Joe X! I appreciate your help!!!!
