slot port question
If I'm making a box let's say 20" in length and my port needs to be 30" long at 3" wide and I'm putting it in the middle of the box to help strengthen it when I make the port turns do I slit the 3" wide into two 1.5"? Also how do I measure the port length when it splits if I'm suppose to cut the width in half? How far from the back wall if I do a 180degree turn? Any and all help appreciated. (Just ordered 2 sundown x12s want them sounding their best!)
The T shaped port split width in half as it turns as you said, the physical length of the port is measured along the center line, same if the turn were 180 deg, for a t shaped port, L1 + L2 = length you entered in Torres or similar software.
Thanks.. One more quick question about port area. When I design I'm shooting for about 12" port area per foot. Does it matter if the port area square inches is a little high...what should each be
The "port area per cube" rule isn't a good way to figure out port area. Some subs need much more than that and some need less. For X12's Sundown recommends 40 sq in of port area each and I wouldn't recommend going under that.
As fas as having more port area than you need, there really is no disadvantage to having more than you need other than it takes up more space. From a performance perspective having more port area won't hurt you one bit.
Builds:
Assuming 1" wood thickness and a T shaped port, the specs would lead to ~3 net per driver @28Hz tuning 81 square inches of total port area.
Yes 1" wood my question I guess would be will these box specs work well with 2 x12s... Only my second time making a box... First time using a slot port and wood isn't cheap lol want to get it right the first time around, total space is 40 wide 25 Long height not really an issue if anyone has has a better design for me... 4dr wrangler
  • Who's Online   0 Members, 0 Anonymous, 2915 Guests (See full list)
