which would be a better midbass (prv)
zoeboi954
(read carefully, try not to confuse mr and mb)
All right i have prv mr600-ndy speakers and i plan on running 3 speakers in each front door 2 midrange (mr600-ndy) and 1 midbass now i cant decide to go with prv mb600 or mb500-ndy reason why i am having trouble is because the mb500-ndy has a lower resonant frequency and lower qts but the mb600 can take more power but its frequency response is smaller than the midrange mr600-ndy...... or am i over thinking this and just say fuck it and go all mr600-ndy
heres the specs for the speaker
midrange mr600-ndy
http://www.prvaudio.com/pdf/8MR600-NDY-Datasheet.pdf
midbass mb600
http://www.prvaudiobrazil.com/pdf/8MB600_Datasheet.pdf
midbass mb500-ndy
http://www.prvaudiobrazil.com/pdf/8MB500-NDY.pdf
the sub im using are the 4 Fi q
heres the build so far
http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
How are you crossing them?
i was thinking 60hz around there
No, how are you crossing them? No reason to use three different drivers if you aren't going to cross them at appropriate frequencies.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
i hope i answer what your asking im going to cut it off at 60hz(maybe) using the settings on the crescendo s1500.1F bandpass amp, i guess thats consider active. I dont know the offical setting till i get it and tune it towards my liking.. i want the midrange to take care of the vocal and up the midbass take care of the kick but i still want them to both blend to take care whats in the middle..
also im thinking of running a digital signal processor but dont know if its really needed or not. bare with me this is my first actual big system so i'm learning as i go
I think what he meant was what are you crossing each speaker at. Like midbass 60hrz_200hrz, midrange 200hrz-3500hrz, tweeter at 3500hrz-20000hrz. Correct me if I'm wrong.
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
