Will someone verify my ports?
Drivers: (2) Sundown x10 V.2
Desired internal volume after bracing and driver: 2.15+
Desired tune: 30hz
link for my design in sketchup: http://www.mediafire.com/download/rjdfh30ejcejl61/SubBox_forX10s.skp
My questions are: did i measure the port lengths correctly? the numbers i came up with are close to the ports on the model.
is there enough surface area? I got the number from the sundown website for the 1st version, and added a bit, 31in^2 on one, and 29 almost on the other.
Early 1999 F-250 Powerstroke , Extended Cab
Current Audio Future plans
5 Cu Ft, shared chamber, 28hz
(2) Sundown x-10 D2 V2
AQ1-2200.1 @ .5ohms Mechman 240 AMP Alt
2 Batteries stock + (1)XS Power D3400
Kenwood Head Unit
Why not just do a single chamber box with one port?
Builds:
I suppose i could, they were just separated from the beginning due to the odd shape of the first rough draft. Didn't really think about it. Is that port area okay though? I can add a bit with shared port. ill post it shortly
Kenwood Head Unit
Yeah your port area should be fine.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 496 Guests (See full list)
