help
mr505
Hey guys so I'm building a box for my 2 shd 12s how does this design look guys it's 4.5 cubes tuned to 32Hz , 2.25 on each chamberScreenshot_2015-05-28-01-10-002_zpsmgi5l
How much power are you going to run?
You can remove the panel separating the ports in the middle of the box if you want.
Builds:
all be running 2 3500s to them and also I want them like the because one of the shd is the old version and other is new so diffreny cone surround etc last box I made they where kinda out of phase they were in a common ported box
That box looks generic, those drivers are 5K RMS beasts, not even a double layer baffle?
You'd be right about running them is separate chambers if they are different versions though.
Ya I got it from another forum there will be a second baffle so what difference would u make to it
It's all good that it's separate chambers but as far as box specs these guys give nothing and no t/s parameters either so you will need to ask them those infos and go from there, the other thing is all those turns in the port are not ideal, maybe you can make better use of your space so you can avoid them. Lastly the driver displacement shoud be huge, the generic box would lose it's intended specs once the drivers are in.
  • Who's Online   0 Members, 0 Anonymous, 3136 Guests (See full list)
