DD M2A requirments? HELP
I have a 2010 honda accord. All I have is a Optima yellow top under the hood. I am about to do the big 3 of course with all o ga from sky high car audio... replacing the 4 ga as the old settup was fine with the old Skar 1500 RP amp I had.. Now that I have the new amp DD M2a I was just wondering what electreical I should run.. no budget... I cant put a price on quality and doing it right.. I want it to last for a LONG time.. keep in mind this is my daily driver and I like to get LOUD ALOT :) Please help with all reccomendations as I want to get the most out of this amp.. I will also be replacing my factory HU... I am currently running a LOC by David Navone.. not bad but I am in the process of a REAL build.. no more little crap IM HOOKED on BASS. THANK you ALL in advance for your input.
A quality alternator with as big of a battery up front with excellent wiring is all you'd need.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Hey thanks man.. I heard a rule of thumb is like 80 amps per 1000 watts.,, I think I am just going to go with the 170 amp from Mike Singer... Before I buy this.. is there such thing as "overkill" when it comes to an alt? Like what if i go for a 240 amp alt...I was thinking this because I may want to upgrade or strap up amps..etc,, Thanks
170 will not be enough for that amp. you need at least a 240-250.
if you cant fit it in your honda. i recommend going custom and building a bracket. if you can only get a 170 in there Id put a big battery up front and a big battery in the rear.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
