need help box build 2 sundown sa 12
punchy
To get better performance you need to do everything as best as you can and to do a lot of experimentation, playing with the position of the box is really important, the box above can be used firing everything backwards or forwards mainly if your seats fold down, if you are firing backwards the box needs to have some free airspace around it so that sound waves can make their way to the cabin. have some pics of the trunk?
For a forward firing setup you will need to make sure the car bracing does not cover the port at all and you will need to seal off which is some extra work, firing back looks also possible as long as the enclosure back is not completely pushed against the backseats and there's enough port clearance, need to check that, from the pics both ways are possible is just a matter of testing to see what you will like best
Here's a setup front firing and sealed off with a center port design just to give you and idea on how it looks:
Ya I'm sure I can do something like that thanks dude your really help full so that box design well work for me I see that that pic of the port is in the middle does that matter
The center port can be done if the port on the side can't clear car's bracing and in the center will.
Well dude thanks for everything but my wife crashed our car and got into a car accident every one and everything is ok but the car is fucked off now so ya thanks bro
  • Who's Online   0 Members, 0 Anonymous, 692 Guests (See full list)
