sbg Posted June 8, 2015 Report Posted June 8, 2015 I have this stupid pop up thing that won't go away. What do I need to do? Every thing I try does not work 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
SIDE SHOW Posted June 8, 2015 Report Posted June 8, 2015 tried to reset it? (battery out and back in)
sbg Posted June 8, 2015 Author Report Posted June 8, 2015 tried to reset it? (battery out and back in) Yes I have, 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted June 8, 2015 Author Report Posted June 8, 2015 Started doing this after a update, and has been like this for weeks. It pops up like every othe time I hit the home button 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
SIDE SHOW Posted June 8, 2015 Report Posted June 8, 2015 lg g3 hard reset in google says to do this http://www.hard-reset.com/lg-g3-hard-reset.html worth a shot....
SIDE SHOW Posted June 8, 2015 Report Posted June 8, 2015 or try email lg and ask them how to fix it, it's prob a common fault if it happened when you last updated it
yeeeaaaa Posted June 8, 2015 Report Posted June 8, 2015 Do a hard reset thats what i did and it worked!
sbg Posted June 8, 2015 Author Report Posted June 8, 2015 Do a hard reset thats what i did and it worked![/quote Take it you had the same problem? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
RainStryke Posted June 8, 2015 Report Posted June 8, 2015 That looks like it's trying to make you select a user interface. I would go into the application manager and clear data on both of them... Then select the one you want.
