Need help with box design zv4 12
I've got a Zv4 12 on an Saz-2000D. First box I ever built/designed (With the help of Joe X). It turned out really good I think don't have any pictures with the carpet on it, oh well.
My box is
2.75 cu ft @ 31hz
42 sq inches of port
0.75 thick MDF with a double baffle and cross bracing with 1 1/4 dowels.
Plays from 24hz all the way up to 40/45hz really well. Seems the output drops significantly after 40-45hz but that's expected with this sub & the low tuning. My box design is different from yours though as it's in the back of my ext cab F150 facing up.
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
Here is another suggestion for 0.75 wood thickness, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide, bracing is 1 1/4" wooden dowel rods:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 1352 Guests (See full list)
