I have some stinger fuse blocks. They accecpt 1/0ga wire. They have 2 slots for fuses per wire. The most i have seen for mini anl fuses is 150a. if i use 150A fuses will it be limited to 150 amps or will it double at 300 amps since it has 2 slots for fuses per wire?
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
Specific model number would help, but if I recall, it is a 1/0 in, and 2 4 gauge out, so 150a per 4 gauge out would be perfect if it is the one I am thinking about.
But like I said, a link to said product/model number would help greatly, or if you can post a picture.
If it only accepts mini ANL fuses, i doubt the outputs are 1/0 as well.
so i will have 300amps worth of fusing per run of 1/0?
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
