Fiat Palio Box Sundown X15s D4s x2.
Hi
Recently purchased two Sundown Audio x15 D4s which is a miracle as I got for alot cheaper then I could of imported it. My only concern is I got the d4s as there is no d2s left. Not quite sure if my Taramps Hd8000 20hm is Cea Rated so Im abit worried about having the wrong subs for this amp. The manufacture claims the amp makes 5256wrms@40hms at 12.6volts and 6305w@40hms at 13.8volts. Should I be concerned as I don't want to get help with a new box design if I have the wrong equipment?
Just limit the amp's gain, the only problem is that you are not going to take advantage of the power the amp can offer.
As JoeX has mention just limit the gain. Ask marlin to help you out. I'm sure he can find time
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
You could try 3.5-4 cubes per sub and just pay attention to the gains. That's a lot of power so you need to set them lower.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
That's good to hear. Each sub as per sundown website needs 68sq inches of port area. So best would be a 10inch port (78sq in) per sub. But you could get away with two 6inch ports per sub. Best would be to do a slot port cause it might be difficult to place round ports for your subs. What are your max dimensions again??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   0 Members, 0 Anonymous, 9797 Guests (See full list)
